NES Control Pad Conversion FAQ
HOW TO CONVERT AN 8-BIT NES CONTROL PAD TO ATARI 2600/7800 (2-BUTTON).
AUTHOR: Graham.J.Percy
EMAIL: gjp57@yahoo.com
PHONE: (61) 03 5978 7198
FAQ Version 1.0a, 18th September, 1998.
Copyright (c) 1998 Graham.J.Percy
All rights reserved. This document may be reproduced, in whole or in part,
provided the copyright notice remains intact and no fee is charged.
The data contained herein is provided for informational purposes only.
No warranty is made with regards to the accuracy of the information.
1/ Find a good Atari 2600/7800 two-button joypad. (Check that all functions
are working. ie 4 directions and 2 buttons). Remove the back of the
joypad and desolder the joypad lead from the Printed Circuit Board (PCB).
(You will need the lead later).
2/ Find a good 8-bit NES control pad (eg. Model NES-004E) and remove the
back. Check that rubber mounted electrical contacts are in good cond-
ition. Clean if necessary.
De-solder the NES lead, the two discreet resistors (R1 & R2, see below),
and the 16-pin chip and discard. It's important not to damage the chip
connection points on the PCB. To this end I find it helps to carefully
file through the legs of the chip to remove the chip body, then the chip
pins can be desoldered from the PCB individually.
POINT "CE"__ ______________________________________________
| | o R1 o oU |
V | o R2 o oV |
_____________| ABCDEFGH oW o o|
/ ---- ---- X X X X oooooooo R S oX |
/ 0 X X X X -------- Q X X X X |
| X X X X | chip | X X X X oY |
| -------- X X X X |
| 0 0 0 oooooooo T |
| IJKLMNOP |
| 0 |
|________________________________________________________________|
3/ Use a razor blade or small drill to cut the circuit on the PCB
adjacent to the board edge at point CE (common earth). This seperates
the button-common circuit (ORG) from the earth circuit (BLK).
4/ There are 8 vertical black strips on the PCB which are high value
printed resistors. They must all be disconnected from the circuit or
otherwise removed (eg. by scraping off). To this end:-
- Use a razor blade or small drill to cut the circuit on the board
directly ABOVE holes J, K, L & M.
- Do the same at the very end of each of the black strips on the right
(at points Q, R, S & T).
If you have a multimeter then check that hole H is not connected to
any of the other chip holes (A thru G and I thru P). If this checks
out then you are ready to begin rewiring.
5A/ The following connections will allow buttons B & A to be used as
Atari buttons #1 & #2 respectively. If you wish to connect and use
all 4 NES buttons then go to STEP 5B.
Using insulated solid core hook-up wire (eg. bell-wire 1 X 0.6mm)
and by passing wires through the back of the PCB, connect the
following hole pairs:-
B TO P
H TO I
A TO G
Goto STEP 6.
5B/ Using insulated solid core hook-up wire (eg. bell-wire 1 X 0.6mm)
B TO N
E TO P
H TO I
A TO F
Using a small dolop of solder bridge across the following holes:-
F TO G
& N TO O TO P
6/ Solder two 1/4w, 620 OHM resistors in place of R1 and R2. (Resistors
from the Atari joypad may be used).
7/ Pass Atari joypad lead wires through the back of the NES PCB and solder
in place as indicated:-
WIRE COLOUR HOLE (SEE ABOVE DIAGRAM)
brown J
green K
blue L
white M
black U
yellow V
red W
orange X
8/ Reassemble the NES pad case. You now have a 2-button NES control pad
which is electrically the same as the 2-button Atari joypad!
The NES controller makes an excellent pad for the Atari
2600 & 7800 with fine sensitivity. HAVE FUN!
NES BUTTON "SELECT" "START" "B" "A"
ATARI 7800 BUTTON #1 #2 #1 #2
I would appreciate any comments you may have on this modification,
particularly if you try it yourself. Good gaming! GP
