If
you've just dug your old videogame system out of the attic, you might
not remember exactly how to connect it. They're not quite like modern
game systems, and may require something extra to connect it to that brand
new TV you have. To the left is the cable you should see attached to your
videogame system. It is typically called RCA, and you will have to use
some sort of adapter before you connect it to your TV. While it looks
like it should fit into one of the composite jacks (and it will actually
fit), that will not work because the audio and video signals are being
carried in the same cable. In order to use the composite jacks on your
TV, you will have to separate the audio and video signals somehow (described
below).
The following instructions are relevant to most vintage videogame and computer systems that connect to a television. Specifically, the Atari 2600, 5200, and 7800. However, if you have the 4-port (four joystick ports) version of the 5200, you need a special switchbox. Try eBay or Best Electronics (catalog item) for this proprietary switchbox. If you have the 2-port version of the 5200, you can use the methods described below.
Coaxial
Composite
Speaking of demodulators, you can simply use one of these instead of taking up all that space with a VCR. Unfortunately, these are much more expensive ($100+) and you're not likely to find one in a thrift. Unless you're going to make a hardware modication, we really recommend using a straight coaxial connection, because going through a VCR/demodulator defeats the purpose of a composite connection. |
